Someone posted a copy of an old (1976) paper that has a discussion of history of voltage levels:
208V Systems and ANSI C84 from 1976 ASHRAE Symposium
I read most of the ANSI paper and the linked post in the other forum. Most of it jibed with what I remember from my youth. I was born in 1957 and I remember the AC voltage as being 115vac when I was young and then at some point it was reported as 117vac then 120vac sometime later. My dates don't coincide exactly with the dates in the ANSI but line voltage has never been exact, and I'm going from memory of something that was just accepted as is.
In reviewing a bunch of schematics I have for vintage Gibson and Fender amps, the line voltage - when designated - is anywhere from 110vac to 125vac, a Gibson Les Paul GA5 is spec'd to work from 105-125vac. So as for a standard for line voltage, there were plenty
None of this surprises me, it's just that the Blonde Bassman blew up it's power transformer and the owner wanted it re-wound. After re-installing, the voltages were quite a bit higher than expected (higher than the last time I worked on the amp, AFAIR) so that sent me looking around. I contacted the company that did the rewind to get a better understanding of how a rewind is done and they confirmed my belief that the xfmr is torn down and the windings are counted one-by-one and then rebuilt with the exact same amount of turns.
The owner got back to me and told me his research showed other amps of this vintage with the tube chart AC line voltage listed as 110vac as well, so really there is nothing wrong. It's just the vagaries of line voltage until the 120vac became the accepted and used standard across the US.
Thanks everyone for your replies, it generated some real useful information for me. Even after servicing hundred's of vintage amps, there are still some basics that can slip by
