1176 ae 2:1 ratio. Need some help calculating resistor values
YLab
Quebec, North Pole
Hi, i want to modify my pair of diy mnat 1176 rev D to have the same ratios as the 1176ae.  2:1 4:1 8:1 20:1  So no more 12:1 ratio but a new 2:1 ratio.  Here's a drawing with what i think are the right resistor values.    To resume how i have done it :  R19 is now the sum of R19+R20 to get the 8:1 on the button where the 12:1 was. R20 get the previous R21 value to get the 4:1 in place of where the 8:1 was.  The new values of R21 and R22 are taken from Igor 's 2:1 ratio on his 1176 51x.  Same logic for the second side of the switch.
I would be pleased if someone could double check my changes.  Or maybe if someone have the 1176ae schematic!
Hubert
pucho812 said:
Thanks! Well, I have to build one first :)
But, think I'll include this mod on a 2-1176D
Hi, yes the mod work perfectly. I have a pair of 1176 that have the mod just like the schematic that i have post and they are great as buss compressor.  Really different than the 4:1 ratio.  Slower and smoother attack i would say.  The side chain hi-pass filter on igor's 51x 1176 is great too.
pucho812 said:
If you look closely, the schematic in the 1176ae manual is not the 1176ae schematic. Normal ratios there. If someone have it it would be great!
Hubert
Good :) Thank you!
Just thought I'd chime in. The values in the above schematic seemed logical for a 2:1 so I did this quick mod as well. Wondering now how this mod isn't more common place. It tremendously increases the usefulness of this limiter into glue-compressor territory. It's easily the most transparent of all the ratios and much reminiscent of some of the best mastering compressors I've heard. It's also much easier to dial in just the right amount of compression due to the transparency.
I see how back in the day the original design was more of a fast peak limiter so 2:1 wasn't a priority. Today when 1176 is first and foremost a sound shaping device I would recommend always doing this mod. I always had trouble justifying the minute difference between 12:1 and 20:1 ratios. No hard feelings losing one or the other.
Can't believe i missed this thread!  Dumb question, if the unit is in "bypass" or off on the hairball kit, would that be the same as 1:1 or does that take things out of circuit?
I've been thinking of building a "new" ratio board to do 1:1, 2:1, 3:1, 4:1, 8:1, 10:1, 20:1 and "all buttons".
gswan said:
Have you actually measuerd the compression ratio at 2:1 or just assumed that it is 2:1?
Not assumed, but estimated from the resistance values available from the schematic. As you know the right side switch bank can be "ignored" from the estimation since it only changes the make up gain of the control amp. The result is in the ball park but R58 should be more like 100ohm for more accurate scaling of the "auto" make up gain. Otherwise the 2:1 setting will be a bit louder than the rest.
Noticed just today this awesome post.... are you sure guys it can works?
I would to do the same for my third unit ( just like ea 1176)
Do I have to follow the mod attached in the first post?
Has anbody actually measured the 2:1 ratio with this mod? I'm getting closer to 4:1 ratio, and the threshold point seems to be shifted way up (that is, I have to feed a louder signal for the unit to start compressing).
Hubert
So Iam very interested in this mod too :)
Are the resistor values confirmed ?
I think this table should help me to transfer it to the hairball unit i guess?
I own A 1176 MNATS REV A unit
The compressor has a soft knee so it's most likely that 2:1 isn't really 2:1. It's probably why the original started at 4:1. Ratios below this tend to get messed up by the knee which gets softer for lower ratios.
I measured the ratios of all the settings when playing around with this in a 2-channel build and found them to be inconsistent, as expected. There are too may tolerance and temperature variables to get accurate ratios in a single channel, let alone two identical channels. It's not a compressor that I'd use in a stereo configuration.
thanks for your input - so you wouldn't recommend using this mod on a single channel Rev A either ?
