1176 edits
daArry
londaaan
Hey
Gonna breadbrd a simpler psu for a dual1176 with components i have already, is the components I've marked on the attached image okay for chop? and is where i'll be feeding the 30v and -10v all good? Finally, just to clear up confusion on the meter switch, is pos 1 correct?
Chop looks ok to me...feed points look good: -10V between R45 and R82, +30 feeds the collector of Q15. Share your PSU schematic?
Do you mean is that postion 1 you've marked or is the meter switch PCB itself correctly layed out?
http://notapplicable.co.uk/audiolab/1176/1176-psu.jpg
Its just a basic adjustable 0-30+/-V LM317/337 ckt - that coo?
yes, is that pos 1?
cheers
Looks coo to me!
yes, is that pos 1?
In the full anti-clockwise position your marked point 1 would connect with pole A of the rotary. This appears to ground the input of the gain reduction control amp at point 22 on the schematic, making it the G.R. Disable setting.
