I guess when you consider the amount of people totally profiteering off the api name I dont blame them for putting everything under lock and key, I think if I was in their same position, Id do the same thing... Its easy to figure that one of the main reasons why there are so many neve clones is the crushingly thorough documentation that neve provided about the modules... I think if there was an 80 page book for the 550a like there is for the 1073, we'd probably see more of those cloned by others... so far the only guy to really clone the eq is a guy that fixes maybe more of them than anyone...
FWIW, I have a bunch of 325's that have different generation black 2520's on them and while I've never sat down to do an under a microscope A/B with them, I never noticed much of a difference between the modules at all. Compare that to changing out the caps for panasonics where I heard a HUGE change in sound from one to another with bc caps. Its quite possible that the blue ones might sound slightly different if possibly you had it next to a black one for comparison but I speculate that in a mix youd have trouble picking it out, if its a 2520 you are doing pretty good... I'll take whatever blue ones you decide not to buy...
When you build your pre's, the caps you should definitely listen to are the axial BC's available from digikey, they are the same phillips caps that were in the api consoles originally and they have the same ballsy midrange. I dont notice too much change between old api amps with original caps and the ones Ive replaced with the BC caps and I tried a lot of caps before trying those and wasnt digging anything until I tried the bc's. Good news is they are really cheap, well, cheap compared to black gates. If you are looking to get close to the real api mojo, Id definitely take a listen to those for sure.
dave
