Just be aware that dual potentiometers usually don't track well between sections.
Bri
True, there will be some variance, so depending on what level of precision the OP is looking for, a dual pot may or may not be a good solution.
If you need super precision between the 2 signals and really feel like nerding out, look into I2C digital resistors. You can control these with an Arduino that is the size of a postage stamp. A single pot on an analog input (0-5V), and the code can translate that into whatever is needed to set the digital resistor to the right value. It's all math, so you can put whatever curve you want in the code. Linear, reverse linear, log, reverse log, audio (which
is different than log) - whatever makes you happy. I've done a small amount of research on these and some of the digital resistors are better for audio than others, so the google will be your friend. I've not used them since I haven't wanted to build something that could benefit from them (yet).
Thinking about it for a second (
"where could these be useful?"), these could be used to make the worlds fastest compressor. 🤔
