2 to 1 passive summer
Coldsnow
Ohio
Hi all,  I need to send 2 mic preamps summed then use another as the makeup gain. I know there would be a resister on each plus and negative line coming in and another strapped across the positive to the negative for impedance.  Any idea on values ?
I'd be curious too , I made a " Y " cord with inline resistors [ don't remember the values ]
for summing two gtr lines together - two pres handling either  2 mics , mic direct , two directs,
but I didn't consider the impedance part of it
Yes, I have done this but would like others opinions.  My thought is to use a 10k resister on each input.  The shunt would be a 266 ohm.  This my thought based on ny daves formula for a 150 desired output impedance, 1600 input, and 2 channels.
Somewhat depends on where it's coming from and going to  [ impedance wise ] for gtrs
I didn't worry about it , but now you mention it think the impedance resistor could be worthy
Does the one you are feeding them into have a line input? If it does this could simplify thinks and improve noise performance.
