These are 1amp diodes IIRC; so you can't expect to draw more than 700mA DC. Since the fuse is rated at 2A, I would think the original diode to withstand at least that. If you don't intend to draw more than 500mA at 48V (which allows about 32 channels of shorted mics or at least 50 channels of working mics), these 1N4003 should be adequate.JW said:This is two diodes in a package sharing the same cathode correct? (See pic)
If so I shouldn't have any pins shorting. I do though. Between cathode and one anode. So, that seems to be the problem right there. Will 2 1N4003's do? I have those.
Reverse voltage is what you want for the voltage you want to rectify; when the diode(s) is reverse-polarized, i.e. not conducting the voltage across it(them) is 2.8 times the nominal ac voltage. For a 50Vac winding it's 140V. For a bridge rectifier this voltage is shared between two diodes, so the 200V rating has a safety factor of almost 3.JW said:Thanks so much for the help you guys. How about this one?: https://www.mouser.com/ProductDetail/Vishay-Semiconductors/UG2D-E3-54?qs=sGAEpiMZZMtbRapU8LlZD0HbIjlpuZ44PERzWWHpHCU%3d
I'm not very familiar with spec'ing diodes. The 200V rating is max reverse voltage right? Forward current is what we want, 2A.
Forward voltage indicates how much voltage is lost in the rectifiers; wheteher you loose 1V or 0.95V is moot. Rectified voltage is always lower than 1.414 times Vac because of this and resistive loss in the windings.Says forward voltage is .95V though. I don't understand this figure. But 1N400x are 1V forward voltage, so must be okay?
You should have chosen 105°C type.Aref said:Hi,
I got a same exact issue with the studer 089 psu!
Just changed two big screw-mount caps (frako2200uf100v105*) with new ones (non scew 2200uf100v85*).
The cap itself is not at fault. You may have reversed it or have it touching another component.Ended up with a blown fuse!
Not at all. Urban myth.Someone mentioned to discharge new caps before turning on the psu. Does it really matter in case of new caps?
