25-way "DB25" D sub connectors, new
pvision
Brighton, UK
New, bought from Farnell. 25-way DB25 D-sub connectors plus metal backshells
The connectors can be used panel-mounted or in a backshell to make up a cable
Ideal for 8 balanced audio connections in the standard Tascam format and for making up DB25 audio patch cables. Enough parts to make up six patch cables
The backshells are metal (not plastic or metallised plastic) and have cable entry at 45 degrees to make cabling easier. They are supplied with four different sizes of cable entry gland so you can get a decent cable clamp setup. Metal backshels mean they won't break when trodden on...
I think these are the backshells
http://uk.farnell.com/mh-connectors/mhd45zk-25-k/backshell-d-nickel-45dg-25way/dp/633860
I have:
05 off - 25-way female DB 25 connector
12 off - 25 way male DB 25 connector
12 off - metal backshells with strain relief & extended mounting screws
£40 + postage
Tascam standard
http://tascam.com/content/downloads/products/221/DB-25_Pinout.pdf
Nick Froome
