One thing after another I had completely forgotten about this project, even though I had finished it years ago. However, I am not sure if there still be interest to the rack. At the same time I am running out of space, so, I have decided to put the prototype rack up for sale in the BM. But doing so I will complete the documenting of the project.
As it goes, a picture speaks a thousand words. So, below pictures will speak a few thousands of that. However, just to refresh our minds that the rack is 4U high, the module width is 2" and the number of slots is 8, hence the name System 428.
Each slot has two independent inputs/outputs. Therefore the system supports either 8 stereo or 16 mono channels or a mixture of both.
Edge connector pin configuration.
Edge connector backplane front view.
DC power connections are made but I have not soldered the connectors. For solid state power (on the left) I have incorporates 9 pin EPIC type connector. For valve power (on the right) I have not selected anything yet.
Audio connections. Only slot 1 is shown. Slots 2-8 repeat.
Input / Output 1 are through XLR.
Input / Output 2 are through TRS.
Insert Send/Return are through TRS.
Input / Output 1 & 2 are also available at SubD25 connectors following the Tascam standard.
DC Power connections are made to the edge connector backplane. Ithe colour code is not set in concrete. I used whatever I had in hand.
