2n3055 replacement
abbey road d enfer said:
Correct. Do you suggest using BDY38 as a replacement for 2N3055? I would think most aspects of performance are inferior, and BDY38 belongs to museum...
Mojo is what makes objectively inferior parts sell at a premium.
Even if transistor gives nothing to the final result, I'm sure all theese Motorola 2n3055 purchased at ebay - all gone for Neve clones.  ;D
And most of them are in fact different parts, but re-badged. Some may even be "better" than an original 3055. :(
The original (slow) 2n3055 process was abandoned sometime back in the 70s. Modern parts can't help but to be faster/better.
I am not smart enough to speculate about designs without looking at them, I will trust Ian's judgement that it shouldn't make any difference.
tardishead said:
I have a lot of Neve equipment with BA283 output stages and some of the old transistors are probably a little tired
No they're not.
If they work they are fine
tardishead said:
He recommended to get more top end and clarity I should replace the 2n3055 with something with a bigger hfe and higher operating conditions.
Then it's not a Neve anymore
tardishead said:
Has anyone noticed the differences between brands of 2n3055. Some are very poor.
Use On Semi, Toshiba,  Motorola in case any of your 2N3055 transistors fails.
Although I still have to see one fail in a Neve circuit
