abbey road d enfer said:As I wrote earlier, standard 10% Log pots are optimized for a 1:100 ratio.
That is true for a potentiometer (3-wire connection), but in rheostat mode (2-wire), law-steering resistors have a very limited effect.john12ax7 said:This is true, but when you slug the pot you essentially change the taper to a higher value.
abbey road d enfer said:That is true for a potentiometer (3-wire connection), but in rheostat mode (2-wire), law-steering resistors have a very limited effect.
Not with a Log or RevLog pot. 33k over 10k (for a 10% Log pot) does not do much.john12ax7 said:I would disagree. Take a 100k pot with 10% taper. Put 100k in parallel and you end up with a 50k pot at 18% taper. Put 50k in parallel and you end up with a 33k pot at 25% taper.
It depends on the range you want to achieve. 20% is good for 1:25, 30% for 1:10warpie said:So what is considered good? 20% taper or even higher?
Not really, unless you accept a limited range like 1:4 or 1:5Also, is there any elegant solution for using a linear pot on this specific topology?
That's the ratio between the lowest frequency and the highest.warpie said:Sorry abbey but I'm not sure I fully understand what these range ratios are.
Yes.warpie said:So for a 20Hz-250Hz that will be 1:12.5? Do I get this right?
That's correct.warpie said:Thank you. So in my case I guess a 25%-30% pot would be the most suitable.
abbey road d enfer said:Not with a Log or RevLog pot. 33k over 10k (for a 10% Log pot) does not do much.
Agreed!john12ax7 said:It works quite well with log and revlog, or maybe we are discussing different things? Certainly at the midpoint of a log pot the parallel resistor will have less effect, but that's exactly the point, since it's effect changes over the whole rotation subsequently changing the taper.
Suppose you need a 50k log rheostat @ 20% taper. To mimic this you can take a 100k log @ 10% taper and put a 100k resistor in parallel. You effectively end up with a 50k @ 18%.
