rafafredd
Thanks Tamas!
How much Idss do you think is necessary on the output pair to drive a 600Z transformer?
The BL series goes up to 12mA according to datasheets, but I don´t know in real life...
I don´t think it would be a nice idea to use a matched P-pair (2sj109) for Q6 and Q7, because Q6 can be in BL range and Q7 should be more than 10mA, so if I´m going to select the higher Idss ones for the outputs, that would be a waste, no?
I think it would be better to use two pair for two opamp and as those are matched pairs, I would only need to to select once for a pair of opamps.
So, I´ve found 2sj109, but they don´t specify if it´s GR, BL, or V, but I hope they are high Idss... Will get some for testing.
