3 PSUs in one case
G
Guest
Guest
I am thinking of putting 3 PSUs in one case
each PSU has a on/off SPDT switch for mains on/off
What is the best way to do this?
3 separate IEC inlets grounded to a single point
1 IEC inlet with distribtion three sets of wires to the 3 x on/off switches..
I want to do the 3x IECs but want to make sure I am not doing anything stupid to zap myself
you should wire from a single IEC to the switches and then add a fuse on the + leg before you get to the transformers. You will be all set.
Sleeper
You can do both, but why would you want to use three power cords?
Best regards,
Mikkel C. Simonsen
