3D "AIR" EQ - "Night EQ" PCB's Complete!
The schematic I'm making (for now) will only be the fixed 2.5k band & the switchable shelf = 5k, 10k, 20k, 40k.
Kevin, not bad idea at all :thumb:
Maybe I could make some nice 2U cases for 8ch. of 2.5k band & the switchable shelf = 5k, 10k, 20k, 40k. We could organize some PCBs order and have a group buy. I know how this AIR sounds and I liked it from the first moment I heard it.
[quote author="khstudio"]
I may start breadboarding just the "air" band tonite.
QUESTION:
I mentioned a few times that the circuit is parallel = 1 is the raw signal & the other EQ - the EQ pots are summed using 5.62k resistors (6 TOTAL) If I ONLY build just the "AIR" band I won't need all the summing resistors :? BUT, won't that change the impedence :?: And how should I compensate or do I even need to :?: :?: :?:
Kevin[/quote]
I'm not familiar with the exact functionality of this unit (a pic of the frontpanel would be nice, couldn't find a decent one).
But let's try: OK, so there's one 'dry' path to an output-summer and several parallel paths doing a certain frequency band ? If you only want one then no corrections needed I'd say. Since this is a pile of opamps doing filtering & summing all will be 'independent' I assume.
So just try it, I expect it'll just work.
Nice work !
Bye,
Peter
Nice work khstudio. I'm gonna take look over this the next few days.
One thing I noticed, and it's very, very minor. It looks like you used the resistor symbol for the inductors L1 and L2. Look for a symbol that looks like a coil... looks like the primary or secondary side of a transformer symbol.
:guinness:
Thanks for posting this :thumb:
Is the sum-collection-point at the top-side of R31 (@U5) ? Label might be missing.
edit: no wait, I see 'EQ-sum'. But what's U5 doing ?
Peter
I'm in a session right now after getting about 4 hours sleep :sad:
Please post all the questions you want & I'll be back in a few hours.
I am aware that some corrections are needed.
Greg, I'll fix the inductor :thumb:
This is a great EQ, it's the poor mans GML. Leaving out the other bands would be a mistake! Please see it through and do a full unit, I have wanted one of these for a long time and would love to be able to build myself one.
Massenburg had said i believe that he put his bands in paralell
becuase it sounded better although it limited the max boost
I have a schemo someone had made without the servos
Nice work KH
Here is an updated version with my idea of U5 - I'm open to correction....
DELETED
Changed some of the resistor values to match those on the PCB.
The stranges thing I can't figure out is the 2.5k on the high shelf & the switchable one don't seem to be using the same cap values...check it out please... but it is right.
I think they have done this to get different Q's.
I've simulated the values & they seem good for the bell bands, never sure of where the effective freq is for a shelf. The shelf EQ's are in the right ballpark though.
