[quote author="Harpo"]Hi Kevin,
some input to your hard work (hoping it is useful). :thumb:
your summing resistor R37 is part of the summer U5. Increase R37 to 56k to set this inverting stage to AV = -1. (AV=-R30/R37).
The modified Full Band will need an AV of about 10 to behave as your airband so R11 at 10k and R9 at 1k will set this AV. (AV=1+(R11/R9))
The full schemo has a minor error at R47. This resistor is switched in parallel to R26 when in Balanced mode and C14 can block DC offset.
For usual the 22pF C13 is a compensation cap and for NE5534 (U5) close between pin 1 and 8 (trace-side?) or use this cap as shown in the feedback path for the dual NE5532 witch has no compensation pins.
The 2.5k shelf band is drawn as 1.2k shelving, so leave out C51 or set C3 and C51 to 470nF each. (-3dB hpf = 1 / (2pi * R9 * C3||C51).
Calculating from your shemo the airbands are at 2kHz, 4kHz, 8kHz, 17kHz and 36kHz, so a bit off the frontpanel labeling, may be correct with real world caps.
all the best
Harpo[/quote]
Awesome :thumb: :green:
#1
You are right about R47. I rechecked it against the REAL PCB. I will fix that ASAP.
#2
I do not think U1 is an inverting stage :? 5 I think is... how would raising that value affect the other summer from the AIR BAND (5.6k)???
#3
C13 does NOT connect to pins 1 & 8 on the PCB... not sure what you mean there???
Will my NEW setup that I drew (posted above) work? I already hooked it up but I can change it if need be. With the 100k pot maxed & 10k resistor to GND should give me 10x right?
If you don't have the PCB I drew of the REAL EQ3d I will send you the file & you can open it with the free software www.expresspcb.com.
THANK YOU for getting involved... I am very excited about this project... when you guys get involved it gives me a jolt to keep going.
Kevin
