cannikin
same here -- PCBs :wink:
There's also 2 (regular looking) green resistors with (Brown, Black, Brown - GOLD)... 3 bands & Green... never seen that, any idea's Question
OUTPUT LOAD ISOLATOR
DECOUPLES CAPACITIVE LOADS AT HIGH FREQUENCIES
* Prevents oscillation and instability in line driving op-amps
* Maintains much lower output impedance than "build-out" resistors
* Non-ferrous core inductor eliminates added distortion
* No effect on audio frequency response or transient performance
* Less than 0.01 dB insertion loss in a 600 Ohm line
The load isolator is designed to isolate op-amp outputs from capacitive loads such as a long cables. Its series impedance is about 0.3 Ohm across the audio spectrum, but increases to about 40 Ohms at RF frequencies to prevent amplifier instability or oscillation while preserving a low audio output impedance.
W.r.t. switching-supplies: a TX for 50 or 60 Hz is big, bulky & expensive.Why would people even use them if they need so much compensation... I DO NOT GET IT! It surely can't be a COST saving issue by the looks of it.
