[quote author="SSLtech"][quote author="rolo95"][quote author="tk@halmi"]Murata/CD Technologies fabricates DC/DC converter that make 24V, 48V and 72V out of 12V. 3W max. I have used the 5V input version to get phantom power from DC heater supply of tube amp. Must add RC filter to output though. Should cost $15 or less.
Part#: NMT1272SC[/quote]
http://www.mouser.com/Search/Refine.aspx?Keyword=580-NMT1272SC[/quote]
Am I mis-reading that, or is it a negative-24 Volt output?[/quote]
Blame marketing. The part is aimed at the telco sector, where they traditionally use positive ground in many circuits. The input and output are fully isolated, so you can connect it any which way you like.
[quote author="The Output Voltage Configuration section of the datasheet"]Although the output is described for negative rails, the input and output circuits are iternally isolated hence positive rails can also be generated, or a mixture of positive and negative. The output +VOUT rail reference can be taken from any of the output terminals to give the range of outputs as described in the Output Voltage Configurations table below.[/quote]
JDB.
[I've used similar modules in non-audio designs. They're very simple to work with, but quiet they're not]
