5 watt SE guitar amp head with sidetone buzzing problem when strings are strummed
rock soderstrom
Tour de France
Berlin
I have modded a China 5 watt SE guitar amp head and I have a constant buzzing background noise sound (when I strum the strings) that I can't get under control. It sounds like something is vibrating with the strings, but it's not a mechanical problem with the speaker or tubes. I've swapped them all to isolate the problem, it does seem to be coming from the amp and I'm running out of ideas now.
Does anyone know the problem or have similar experiences. What could be responsible?
The circuit now is a really good sounding hot Mini Z clone (but with Master Pot) but the problem was already there with the donor amp. Tubes are 1x 12AX7 and 1x EL84.
Sounds like oscillation, try moving wires unless it is on a PC board, your gain went up with the deleted tone circuit, you could try a divider to attended the signal. Maybe a NFB resistor from the xfmr secondary,
I think you're right, I've already opened up all the wiring harnesses but I can't influence the behavior. I think the problem originates on the circuit board.
That's true, but the problem already existed in the original version. By the way, the tone stack had very little effect, sounded terrible and choked the amp. That was a very good decision to take it out. The voltage divider in front of the gain pot had originally also swallowed a lot of gain.
I'm afraid it will change the character of the amp too much, I'm very happy how it sounds now, really great, wild and super loud for 5 watts. This is not my first 5 watt amp, but I really like it now - good recipe!
I'm going to try a grid stopper before V1b, see what that does and I'll contact the transformer primary to the 240V winding to get the secondary voltages down, they're all too high!
Maybe it has something to do with the poorly filtered DC heating?
Well, there’s a few silly things happening in the circuit, but tell us what the noise sounds like. Go to YouTube and put in “60Hz sine wave”. If you can tune a guitar by ear you should be able to tell if this is the noise the amp is making. If it’s not 60Hz try the same procedure with 120Hz. If it’s neither and sound like a boat engine or a ambulance siren, let me know.
Some obvious bad things with the circuit.
1) no grid stopper on the power tube. Helps prevent oscillation. Value is not critical. 10k. 4k7. 1k. Even 100k. Just put something there.
2) no grid leak on power tube. Check data sheet for upper limit on this. If I knew the power tube being used I’d tell ya.
3) a resistor bypassing the tone stack? I mean, why?
4) A voltage divider on the B+ before the output transformer? Why? Just use the correct power transformer. Iron ain’t cheap. The tube might be able to handle the higher voltage. Dissipation is what matters more.
5) DC heaters with just a single filtering cap? That might be your culprit right there. On such a low gain build, DC heaters are unnecessary. AC heaters would be fine.
Yep, I can tune a guitar by ear, but I have no idea what this has to do with my (no solved) problem. I got no 60/120Hz problems because I am in a 50Hz country, but joking aside. There is/was no hum problem, I never mentioned that. It was whirring noise, similar to when parts of the housing vibrate loudly with the strings.
There is a grid stopper in front of the EL84, 3.5K!
It is clearly described in my first post which power tube is used (12AX7+EL84 inside), just read everything before you post.
There is a grid leak resistor now but that was not the problem.
Nonsense, the resistor replaces the tone stack which I completely threw out because it had hardly any effect, sounded bad and stole a lot of level. But I've already written about that in my previous posts. Again, read first, then post.
What voltage divider? What are you talking about?
Not my design, but I know where it comes from. This amp is a generic Chinese design that is sold under many brand names. Gretsch, Epiphone, Harley Benton and so on and the first models had the usual AC heater. There were problems with hum, according to internet forums, and the people in charge went with a (rather poorly implemented) DC heater. I wouldn't do it that way, none of my guitar amps have DC heating, I get them quiet without it.
The main problem with these amps is the design of the PCB, where local oscillation occurs due to crosstalk.
The amp sounds really good now and is loud as hell...
It is also worth knowing if the level of the noise changes with the setting of the controls, particularly the one before the output tube.
No, it doesn't change anything (apart from the overall volume). This is an attempt on a master volume so that the amp can also be played at moderate volumes (in rented apartments, for example). This also had no influence on the problem, as the pot was not even present at the beginning.
This works more or less at the start of the potentiometer's control travel, but from a certain position the potentiometer is then ineffective. There are better solutions for this, but it's not worth it for such a low budget amp. They were sold here for 89€ at Thomann.
(I'm just throwing stuff out there, perhaps pictures and video (sound) would help the diagnosis?)
weird buzzing when you have signal (when you play)?
(I have no idea if this would matter in such a low power amp, but..) output transformer magneto-striction--something something. Sometimes when people obtain attenuators (the kind to reduce output going between the amp speaker output and speaker(s)), they freak out since they hear the OT producing sound (which was present previously but they just didn't hear it before since it was drowned out by the speaker(s)).
(Another one--just a WAG really) A problem is described where the stapled alu shield in the cab isn't making good contact with the chassis and causing weird noises:
Thanks Dai, for chiming in. As already written, it was definitely not a mechanical problem but oscillation. The PCB is the problem from my point of view, with some mods and trace hacks on the PCB I was able to solve it so that it is no longer annoying.
Is this now the best amp in the world? No, but honestly, I would have killed for this amp in the late 80s. Back then we only had the cheap transistor amps that sounded really bad. We're talking about a practice amp that's really fun now.
Now this amp really gets down to business, depending on the volume at the guitar you can go from a little clean to nice overdrive to fuzzy distortion, everything is possible. Surprisingly loud for 5 watts, but with the crude master pot solution and the gain control you can make a lot of noise even at lower volumes. Now the amp is much better than when it was shipped. Definitely.
Just picked up a Marshall G215R CD and man is it loud for two 8" speakers, made in Korea with Park speakers, stereo chorus, reverb, nice crunch and that Marshall midrange thing going on,
Likely that 200 ohm / 220K combo, which has an... academic effect there. The 220k is likely more of a discharge resistor, than anything else (imho).
I'm afraid I gotta disagree a bit here. The 220k bleeder is fine, a good safety drain to have, but a 4 watt 220R resistor on the B+ between the reservoir cap and Node A is both pointless and an unnecessary source of heat that could harm the PCB, especially if it's mounted directly on the board. There's just no point in dropping the B+ voltage. The EL84 can take the higher voltage. If it couldn't, then a different power transformer should have been used. As long as the total dissipation is within spec, it should be fine. If the point of the resistor was to fake tube rectifier sag, that's pointless as it's a single ended amp.
Wouldn't R10 (220 ohm) between C8 and C9 form a CRC stage for the output primary B+?
If so, wouldn't that kind of be a requirement for a low-hum single ended output stage, due to the (relative...I keed) lack of common mode rejection inherent in a single ended vs push pull circuit design? But what do I know.
Edit: @rock soderstrom if this is a screamer, that newly unused 1M pot (and maybe the unused caps) might be able to be repurposed into a bass cut control. I've found it handy in situations like using a Les Paul in the neck position, for higher gain work. Edit again: I mean without messing with the gain. :)
Hey, @dai h. thanks for the trip down memory lane! I used to stop into LV's shop on South Broadway here in Denver for tubes and advice. He knew his stuff. What a character!
(edit: his business was called NBS Electronics, of which NBS stood for No B*ll S*it. I just looked at the video further. I can't say I agreed with his political views, but he sure made them known, haha!)
Ok Mr. / Ms. know-it-all, but you seem to have overlooked an alternate view...
Yes it would, and yes it does.
Worth keeping in mind this is a "FIVE" watt little amplifier, which is also single-ended and without global feedback, so virtually NO power supply rejection. Why would you NOT want to filter the supply voltage?
PS. Spoilers - a resistor, chunky as it may need to be, is still cheaper than silicon parts...
