peter purpose
I would use the right part, but it will not explode if you use 47n. Your choice.
peter purpose said:I would use the right part, but it will not explode if you use 47n. Your choice.
peter purpose said:1. yes.... as per the instructions.
2. I've no idea of the colour codes on the Sowters.
They usualy print them on the reverse of the invoice.
jandoste said:any one didn't use the sowters for their build?
peter purpose said:The two you have marked as 10k are probably too high. Measure your led and use an online led calculator.
R63 is indeed 150R, but you can leave it off for mono.
Meter board 12 to 12... you're just putting a switch in the path.
Most problems with these are down to the wiring. Check your work again.
peter purpose said:It would help if you mentioned the parts you are talking about.
Stick a couple of 2k2 in there and be done with it.
peter purpose said:No chance of what?
