we are going to try a 6SJ7 glass pentode into a 6SL7 phase splitter into a pair of 6L6GC power tubes backed up by a ultra linear output transformer,
this would be a Vox type front end with a Fender type output stage,
done a lot of marshall, fender and vox, now time for combo-nations.
we want a good amp for rhythm guitar, not a def tones crunch-meister.
this means plenty of natural compression with cathode biased pwr tubes and the magic vox ef86 pentode funk, are you with me so far?
ef86 family means "handle with care", amplification can come at a price, ie: noise.
so we simply drop the screen voltage and increase plate resistor to 330 K to drop B+ and noise while retaining most of the amp factor.
OPT is good from 5 to 80K, bottom end should be good, ;D
we will lose amp factor by using 6L6 instead of EL84, so we must now simply run the amp wide open, oh darn!
