AusTex64 said:I built my pair with 6X4's because that's what the originals used. I haven't done a comparison between diodes and rectifier tubes. I agree with Bruno2000 that voltage sag won't be an issue with that unit. I would bet either way will sound good.
The actual significant difference will be 20-30 V more on B+ with diodes. That may impact marginally the performance (more headroom, less THD), but not noise. As Ian wrote, noise performance in tube gear is conditioned by other factors.hugo said:Hi, i can choose between diodes and 6x4 tube on power supply of Drip Pultec v3... WHat do you think about it ? For sure the tube is cool lloking, but in term of performances and noise floor, is there any difference ?
thanks
abbey road d enfer said:The actual significant difference will be 20-30 V more on B+ with diodes. That may impact marginally the performance (more headroom, less THD), but not noise. As Ian wrote, noise performance in tube gear is conditioned by other factors.hugo said:Hi, i can choose between diodes and 6x4 tube on power supply of Drip Pultec v3... WHat do you think about it ? For sure the tube is cool lloking, but in term of performances and noise floor, is there any difference ?
thanks
hugo said:AusTex64 said:I built my pair with 6X4's because that's what the originals used. I haven't done a comparison between diodes and rectifier tubes. I agree with Bruno2000 that voltage sag won't be an issue with that unit. I would bet either way will sound good.
Thanks for reply ! I have one question..There is like a "low noise" system on drip pultec v3.. It it possible to bypass it, but is it a good idea ? Is the noise floor so bad on vintages unit ?..
