tchgtr
If the pots have the square punch-hole in the back of the case, that can be a convenient way to introduce Deoxit.
Definitely replace the 'lytics, especially if they look original. Don't know about higher values.
Leave the ICs alone. That's a lot of work since they are soldered in. The 'lytics will make more improvement anyway.
If the green films are for the EQ, try replacing with some polypros. Maybe start with a stereo pair to see what you think. You'll like it.
From my limited experience, you may get a few busses working with cleaner. Be sparing with some quality stuff like the Deoxit. Operate a switch while looking at the back with a magnifier and you might see the contacts you want to spray.
Whatever you use to clean the faceplate, try a little of it over some out-of-the-way lettering to make sure it won't remove it. Clean the faceplate while the channels are removed.
Enjoy.
Enjoy.
