benlindell
are you turning the gain of the channel all the way or almost all the way up?
zmgwg said:ok you were right, I have 22.6 after readjusting power supply. one channel working, but another have really low gain with transistor voltages different than working channel. input transformer and wiring is ok. 2n3055 is ok. checked all the components except polystyrene that have marking anther them, can it be something elst? there are no shortings and I've reheated all the wiring joints
zmgwg said:is anyone using metal standoffs for pcbs? I cant find any non conductive solution and I dont want too mailorder it [unless i'll have to...]
I came around it by installing standoffs [from the 2u build] to top cover and not the bottom and now it sits nicely in 1u.madriaanse said:zmgwg said:is anyone using metal standoffs for pcbs? I cant find any non conductive solution and I dont want too mailorder it [unless i'll have to...]
Using metal (conductive) standoffs is a bad idea for the EZ1290's. It will short the top left mounting hole (0V) to Case Ground, which is not the end of the world, but not a good idea either. For proper star grounding, low hum, low interference, use plastic or some other insulating standoffs. If everything's wired correctly there should be 10 Ohms resistance between the rack case and 0V on the EZ1290.
M.
