North said:The pads, phase reverse, phantom power and DI's I found the least hassle to get as kits from JLM audio. They build quick and sound great leaving me to spend more time on other things about this build.
useme2305 said:here's the vero layout i made for the dc/dc converter 48V to 2x 24V.
i tried running both pres from one TIP121 but two regulators (one for each channel) are better. one alone can handle the current draw but it
StaticRick said:So it looks like its my turn to ask for some EZ1290 troubleshooting help...
I built two channels of EZ1290. One of them is working great, the other one isn't. The output is much lower and shows asymmetry on the scope.
I've spent a good amount of time visually comparing the two channels. They look to be identical. So, before I start pulling components off the board, I'm looking for suggestions of what to investigate first based on the scope pic below.
The pic is using the same 1kHz input signal that was used to bias the working channel, but I had to turn up the Y-axis resolution due to the lower output.
Left to my own, I'll probably start swapping transistors. I'm hoping that some input here will save me some bench time.
Thanks GroupDIY!
critterkllr said:StaticRick said:So it looks like its my turn to ask for some EZ1290 troubleshooting help...
Thanks GroupDIY!
Can you check voltages using a DMM? Before you start swapping around parts, it's best to run down the circuit with a DMM and a schematic handy. Alligator clip the negative probe to ground and start probing with the positive. Keep notes on all transistor voltages. If one seems odd, you'll know what to start looking. I had a similar problem with one of my first EZ1290s and it turned out I had a bad cap. I would have never found it if I didn't go through the entire circuit to check voltages.
I have recorded more than a couple records on an 8068 and I can tell you, the 1290 pre holds it own. It has everything your looking for in this type of design.madriaanse said:Hi Michael,
Yes, the DPA appears to be using lots of SMD components and uses a vastly different layout compared to a vintage 1073/1084 as found in 80 series consoles. I've heard people say the DPA is a very nice sounding mic pre however. I think you'll hear more resemblance between a well maintained (this is key!!) vintage 1073 and the EZ1290. In order to make the EZ1290 I had to dissect and desolder a perfectly good module to get all the details sorted out. It hurt but was worth it in the end. I'll see if I can dig up some recent clips a friend of mine recorded with an EZ1290 and Wunder CM7 and an R84 (no processing) to give people an idea of the sound.
Martin
sr1200 said:I finally finished my 8ch unit (after 4 years). Started with 2ch, then got 4 more... finally got the last 2 this year. Its been quite a ride!
djn111 said:The trimmer is meant to adjust the amplification between the switched steps, to make them accurate for your need.
