Well ... 8 would be nice, but a GDIY-500 Rack is 11, so I used those little cards to make an 11 PPM meter in 1U. Don't have a good front panel for it yet, but it meters 0dBFS, -6,-12,-18,-24,-30,-36 and -42dBFS. 0dBFS is a red clip indicator adjustable on a per channel basis ( to the overload level of the converter (which varies by converter) ). Has a clip hold mode, and a common reset switch for all 11 channels.
Used Ian's DB25 summing cards to wire up 4 TASCAM inputs (2 input, 2 "through"). The first 8 channels are on 1 DB25, and they also are split 1-6, 7-11 the way my GDIY51X tascam cards split the whole 11.
It will run on a 24V dc wall wart, with a little breadboard rail splitter, with no ill effect observed thus far.
Needs a new front panel, but this is what is there now. Switch has normal/peak hold/(reset)
