Mobius
Member
I need to build a couple direct-to-soundcard guitar preamps that will use bipolar supplies. I want to power each of them from their own AC wallwart.
I have a 24V/800mA wart that puts out 28.4VAC unloaded. Neither of these preamps would draw much, so I should expect to be able to have as much as 28V to use. (Never mind that the wall outlets at my apartment are at 129VAC and I can’t expect that everywhere.)
28V will rectify to almost 40V. I’ll split this in half with a TLE2426. Let’s assume that I end up with -18V/0V/+18V. Cool.
BUT:
I will have (at least) three jacks connected to each box: Guitar in, Line out, and Headphone out.
Where do I connect the grounds of these jacks? Only to each other? If so, will I be able to hear anything when only the guitar and headphones are plugged in, with no hard ground? I can’t connect them to the 0V of my rail splitter because it’s +18V to the outside world, right?
Matthew
BUT:
Matthew
