clintrubber
I've moved my ramblings w.r.t. the output-stage of the Altec 1589B here, might be better suited and unclutter the thread in which I originally added it at the same time
( http://www.groupdiy.com/index.php?topic=23570 )
So FWIW let's have a look at the 1589B output-driver. Nothing special, but a few observations/things w.r.t. the circuit came up, maybe sombody has some ideas or cares to comment?
Here's the output-amp that drives the output-transformer:
(BTW/FWIW, complete circuit is here: www.exemplaryrecords.com/altec1589bmanual.pdf )
#1
Closed-loop gain looks to be determined by R120 (33k) & R118 (100) resulting in a theoretical closed-loop gain of some 50dB (without output-TX).
But instead of some dominant pole to define the hi-freq rolloff there are R117 & C106 to lift it even further (lifting theor. closed-loop gain by a few dB beyond say 16kHz). Most likely to compensate for hi-freq losses elsewhere, but without any additional cap to bring things down again it looks a bit dangerous... time to do a freq sweep when the unit arrives. Maybe in reality there's simply a small cap across R120.
#2
NPN Q103 acting as a diff-amp on its own (in front of the 'VAS' Q106) ? (Voltage Amplification Stage in D.Self-speak)
Never seen a topology like that there before, or I must be looking it at it from the wrong side...
If Q103-E was connected to Q106-C it might have been a bit more familiar (resulting in a CFP/Sziklai) but would still be a weird VAS, so not sure Q103 would actually help things then.
Who knows it's not really connected like that, but since I haven't received mine yet I can't check yet.
#3
CR106 might provide some form of safety, but haven't given it much more thought.
Or maybe it's for some nicer startup-sequence, quickly charging C108 - seems more likely...
Thanks / bye,
Peter
![1589B_output-amp_00.jpg](https://proxy.imagearchive.com/341/34128a3fcf94f67b987a0bdffe649ae9.jpg)
#1
#2
#3
Thanks / bye,
Peter
