a good mic pls
test in real conditions the perfect sound for you. After you have determined the right capacitor, solder it definitively into the microphone
Couldn't you also use EQ and determine how much high frequency cut was desired, and just put in one capacitor that corresponded to the level you determined was optimal? Seems that would be easier. But then I suppose you could just leave the plugin inserted in your DAW channel and save the trouble of soldering at all. I probably wouldn't do that, because it isn't as fun, but seems like an option.
It seems that there is not much experience in recording, editing, processing, mixing, mastering audio material either.
Quite a lot of unknowns for an equation as complex as audio production.
