ramshackles
Hi
I'm new here but have been browsing through for a few days. I'm quite a novice at electrical engineering - however the combination of having to start designing circuits for uni (geophysics), a healthy obsession with playing music and unhealthy obsession with gear gear gear and finally, lots of time but a small (if steady) input of money inevitably leads to.....DIY!
Anyway, I've been thinking about very simple input & fader modules. Something with say a panorama control, mute, polarity reverse, output to a fader module and *perhaps* an insert. The idea being that with a number of these I could output to something like the folcrom summing mixer and some amplifier and I have a very nice, fairly sophisticated summing setup.
Some sends would be fun, but I think thats getting far ahead of myself
My audio circuit knowledge is fairly limited - in geophysics things a different, circuits are generally current driven and we are concerned with measuring different signals. I have a good knowledge of theory and vaguely related things like computer circuitry/programming and electromagnetics :S
I've looked on this site and around for anything similar to what I want but I find mainly full blown channel strips or people trying to make full consoles. Thats way beyond me. Are there any places I can turn to, threads I missed, schematics to look at?
The Small Signal Audio Design is a very useful resource and I'd quite like to implement the active panning scheme, that uses 2 opamps to achieve a very accurate panning curve and maximum width.
One thing that troubles me is bringing the signal level up to the nominal internal level (I think I'd go for -2dbu maybe even -1)...So the first thing the signal encounters is some kind of opamp (discrete or IC etc) to do so, but the signal going into the opamp is not constant? This is noob crazyness I know....
Is going out from this little channel to a seperate fader module and out from that to whatever summing mixer a good idea, or should the fader be connected differently?
Is it a good idea to put a buffer amp between each circuit block (between the panner section, mute, polarity etc) or is that overkill?
If I used higher spec opamps (such as the 990) for gain stages and cheaper IC opamps for buffer things, would that be beneficial? (I know manufacturers might use the best opamps for critical parts, but cheaper ones for where it doesnt matter as much, but I have trouble to identify the 'critical' places)
I've drawn up some schemes of seperate blocks (pan section, mute section etc) but how to connect them all in a low-noise, working, high spec single circuit is different...
Is such a simple input module more complicated than I think?
Thanks for all help
PS, I cant complete anything without a link to my band and a super-christmassy video
http://www.youtube.com/watch?v=zp2z2JlTzxY
Thanks for all help
