> I'm not sure whether this anecdote suggests that this part works at 36V or confirms the validity of the lower voltage limit?
I'm not sure what I meant to imply; only an observation. A 2-point dataset.
I would normally expect solid-state to die "instantly" or live "forever".
Or, since there are long-term leakage issues, say 100,000-1,000,000 hours. Decades or a century. Forever-enough for most human purposes.
Figuring my actual power-on hours, it was close to 1,000 hours each time.
A 20% overvolt caused a 99+% reduction in life. Twice.
It almost suggests that, like car batteries, there is a timer inside. "5-year" batteries never fail to fail at 4.5-5.5 years. It must be a timer. The chip seems to have a timer which ticks super-slow at <28V but faster at >28V.
> de-rated for secondary breakdown or power dissipation in specific internal devices. The failures you experienced may have been anticipated in national's lower voltage rating.
Yeah, yeah, I knew they printed "28V" for some well-supported reason. If they could have sold into 36V markets (albeit at higher impedance), and lived, they probably would have said so.
Rational engineering suggests that surface contaminants and buffers are scaled to a certain life or voltage, and ensure failure if you ask for more than 5 years (4.5yr is acceptable with fine-print warranties) or more than 28V.
But some CPUs do have safety mechanisms which compare the external clock to an internal free-running oscillator. If you apply an over-clock which is too close to the free-running oscillator (which runs at a known multiplier of safe logic speed), it shuts-down. So while I "know" a battery or a 27-transistor chip from 1980 "can't" have a sophisticated timer, my conspiracy theory is not totally legless. Some systems are designed to fail.
In any case: observed 1,000 hour MTBF without an actual timer implies that if I built 1,000 of these units, they could start failing in hours, and my warranty return department would be swamped. $2 chip, minimum $20 repair return costs, $200 bad-will..... it ain't worth it.
Also: if this is in the recording path for live performance, Murphy will make sure the failure happens in the best take of your life.
So I guess my point was: even if it works first-time, even if it works for months, going outside the specs is a Bad Idea.
