pucho812
had a guy try and convince me that a mono kick sample sounds different at 0 degrees vs 180 degrees polarity and that it mattered which direction, in or out, the speaker goes first. This took a long time as he kept interchanging phase vs polarity and finally speaker direction. Having listen to his example of a kick with polarity vs polarity flipped I couldn't denote the slightest bit of difference.
so I put it up to the guys here.
does it really matter on a single instance of a mono kick where polarity is at?
I say no because there is nothing else to reference to. More over you can't really say the signal is in phase as phase would mean he is comparing a relationship of more then one signal which was not the case here. I also added that if it truly sounded different their might be an issue with his system... I say this falls into the realm of psycho acoustics So what say you?
