bieckmusic said:Anyone know why my pad switches don't work? all 4 boards work and sound amazing, very clean.
But all 4 pads make a small click sound when pushed but don't reduce the gain. My hunch is I have the wrong switches.
sure silence with the transformer secondary winding shorted out by your jumpers.soundsactive said:The other pair is full of Cinemag TX and Gar-2520s. I'm not even getting the tiniest bit of signal through them
relates to the psu whos name you kept a secret and further don't tell what load is connected to this psu (maybe 1 or 2 or ... 4 preamps with or without phantom switch enabled and condensor mic connected...).and phantom is inconsistent.
setting the DOA to max.avail.gain, so be aware of a feedback/overload problem when the jumper shorts are removed. Usual min.gain setting would be a same value as feedback resistor (10K?) instead.2 of my pots were shot, so I have been shorting Gain 1&2 to eliminate another problem until I get new pots.
R1, R2 (close matched) and R11 are rated for at least 0.5W and correct value ?soundsactive said:the PSU is the DIYPartSupply PSUniversal. The PSU is only powering one of the troubling channels at a time, to isolate potential current draw issues. When I attach the PSU to the two working boards, 48+ is fine and consistent, however on the Cinemags boards it is not, which leads me to believe that it is a isolated issue to the individual boards.
R6/7 in series with C8 is a provision for a zobel network across the input transformer secondary winding. Parts values depend on type of transformer and selected ratio setting. From your pic both parts are jumpered in your build, shorting out the transformer secondary. Just cut one of those jumpers in order to interrupt this short.when you say i shorted the secondary wirings on the transformers, are you referring to the ratio jumpers or something else?
