3nity
wow didnt notice those jumpers untill now!
cut 1 of them at least.
looking at the pot from the back, pins pointing down, the jumper between center pin and rightmost pin at the pot is missing. Only connecting to the pots outer pins will make the pot behave as a fixed value resistor.dacapitan said:...looking at the pot from the back - far right pin on the pot is at 2 on the board and far left pin on the pot is at point 1 on the board
Most likely cause are dirty/oxydized switch contacts. Some contact cleaner and exercizing the switches might help.dacapitan said:Also the PAD and POL switches are very noisy/scratchy when engaging them
