clintrubber said:Added observation as copied from Black Market:
druedger said:rodabod said:If anyone has received preamps here, or has read about the hum problems, if you have time, then could you contribute any thoughts you have on fixes?
I just put my unit through its paces last night, and the um is bad. I'm sure others have seen posts elsewhere about this, but the main issues are that with the EQ engaged there is a nasty ground loop buzz when the notch filter selection is set to 360 Hz. It seems to be across each frequency selection for that switch. I also noticed that even the hi pass filter has hum problems as well. As you continue to move the switch towards 300, the hum gets progressively louder. The worst problem appears to be a nasty pop that occurs when increasing the gain on the gain switch. Somewhere around 8 o clock on the dial it pops hard. It's so loud that it hurt my ears with headphones on. If it had gone to my monitors, there's a good chance it could have damaged the speakers. It's that bad. So keep that in mind when you get your units.
Does anyone have a schematic for this? When I got the unit I pulled the cover and noticed that there is no star grounding scheme for all the card connections internally. I'm thinking of redoing the internal grounding, but I'd love to see a schematic so I can do it properly. I'm sure I can suss it out just by tracing wires and such, but a schematic would make it much easier and would save some time.
Chance, is there any way you can make schematics available for these units? I hear the ACMP-81 and ACMP-84 units have the same hum problem.
BTW, question for schematic already answered.
I'd say that AC would be better, meaning the reservoir caps inside the preamp-box. But it ain't nookgb said:So A.C. or D.C. ?
mitsos said:...I don't think it would be too off the wall to ask Chance to arrange for new toroids. Not to be a dick, but at the quantities we're looking at, they'd be cheap. Wishful thinking with China I guess, but Chance did offer a warranty and to make things right in case of problems.
