Received the first ACMP81 here is Oz. Another one to come and a ACM1200 mic still.
The shipping, which seemed to be Fedex, is obviously split up into 3 boxes.
Which is a good thing, because the value for customs was around USD 400 for the one pre. (much inflated)
Shipping ended up being around 70% of purchase price USD to Oz.
Anyway - the first ACMP81 out of the box - like others, I get :
- rack on outside looks quite solid. I had to JAM it into my rack though - MUCH wider than normal.
- preamp section is very quiet. I mean *really* quiet at <-90dBu. This is with input and output connected to my Motu
2408MkII balanced in/out, input gain at unity, output gain at unity and signal at -4.5dBFS on Cubase level meters.
A 'normal' working level for me.
- EQ is a real stinker
Adds between 30dBu of 50Hz harmonics when all bands flat and eq engaged
Lo/Hi pass - no effect on noise
Lo and Lo-Mid add about additional 10dBu of noise each
Hi-Mid and Hi add about 15 dBu each.
- Mic switch engaged st the '-80' marking creates a Full Scale blast of noise - ear/speaker popper for sure!
Fix Mode ON
- rework the input selector
- change the eq transistors
- play with power grounding for kicks, then replace with external PS : toroid, JLM PSU and dc connect to preamp
FIX Mode OFF
Should be OK then.
Good thing we live to DIY around here.
Wouldn't want to have bought 8 of these and not be ready to do significant work!
PS - makes me feel better about the stuff I throw together! Quieter than this, for sure
I'll eventually be able to compare with the 2 81's I'm making from Tommy's boards with Carnhills
