ACMP Gain Switch Mods -- Line-In first:
The ACMP preamps all share the same basic input circuitry. The Line input transformer is a 4:1 stepdown transformer supplied by the Chinese with the same load that Neve used to terminate their Line In transformer: 2K2 in parallel with a 2.2nF cap. When I first saw the cap directly across the secondary of the transformer in the schematic, I was suspicious that I would encounter severe overshoot from the transformer due to the capacitive load resonating the transformer. As the square waves below show, I was correct.
Step-down line-input transformers will usually terminate best with just a resistive load. This transformer is no exception. It has excellent square wave response when terminated in just the resistive portion of the ACMP load. With the 2K2 load resistor in parallel with the 3 dB per step Line attenuator, the Line input transformer sees a load ranging from 656 Ohms to 709 Ohms, depending on the gain setting of a '73 or '84.
The "Line In" attenuator network in the ACMP-81, on the other hand, has an extra 510 Ohm resistor (1R68) in series with the stepped attenuator which causes the load on the transformer to vary from 872 Ohms to 912 Ohms depending on the position of the gain control. I'm not sure why the extra loss is put into the '81, but it can be adjusted by changing the value of 1R68.
So here are the pics:
1 kHz ACMP-81 Line Input Transformer Secondary with 900 Ohm Load in Parallel with 2.2nF cap (as delivered).
1 kHz ACMP-81 Line Input Transformer Secondary with 900 Ohm Load only, 2.2nF cap removed.
10 kHz ACMP-81 Line Input Transformer Secondary with 900 Ohm Load in Parallel with 2.2nF cap (as delivered).
10 kHz ACMP-81 Line Input Transformer Secondary with 900 Ohm Load only, 2.2nF cap removed.
1 kHz ACMP-73/84 Line Input Transformer Secondary with 700 Ohm Load in Parallel with 2.2nF cap (as delivered).
1 kHz ACMP-73/84 Line Input Transformer Secondary with 700 Ohm Load only, 2.2nF cap removed.
10 kHz ACMP-73/84 Line Input Transformer Secondary with 700 Ohm Load in Parallel with 2.2nF cap (as delivered).
10 kHz ACMP-73/84 Line Input Transformer Secondary with 700 Ohm Load only, 2.2nF cap removed.
So what do the square wave photos tell us? The line input transformer will be far less harsh and have a much clearer midrange if the overshoot is eliminated. I would recommend pulling out the 2.2nF cap (C2 in a '73 or '84; 1C21 in an '81) in a heartbeat.
In addition to determining that the 2.2nF cap is a bad idea, I also derived a revised set of 1% values for the Line input attenuator resistors that take the maximum error relative to 3 dB gain steps from 0.25 dB to less than 0.03 dB (calculated). There will be additional variations due to the 1% resistor tolerance which will degrade that a little bit, but with the revised values it will still be much more accurate than the original values. The 0.25 dB improvement is modest, however, so changing the resistors is optional with the exception of the 39 Ohm resistor in the '81 which is afflicted by the wrinkly bad coating syndrome and should be replaced along with any other resistors showing signs of deteriorated blue coating. In the revised set of values, only the 200 Ohm resistor stays, and the rest are changed. If one doesn't trust the original resistors, there is no problem swapping them out -- it takes mostly time, because the resistors are relatively cheap.
Next is the Mic Transformer analysis, and the rework of that attenuator network to eliminate the pop and spread the gain steps out among 10 working positions and an "OFF" instead of 11 working positions. This one's a lot harder to figure out than the line in.
