I noticed the shift in input impedance of the resistor ladder too as it is switched. It is slightly unfortunate, but then again, the Neve values shifted too. Perhaps not quite as much though.
In case it interests you, here is a response graph of the stock TNC mic channel versus one which I adjusted the transformer networks for:
Mic transformers can be a bit more tricky since some modern mics present as little as 50 Ohms which usually means more ringing. What I've done in that instance above is set the response to fall closely to the original transformers.
