There's two things that I don't particularly like about Project 93, i.e. the unbalanced input and the use of electrolytics in the signal path.
I'm not quite sure whether to put the circuit in a little box or into the mic itself. The mic's quite big, so it probably would fit in there. But I would actually prefer using the active circuit as an option, so an external box would be preferable. In the case of an external box, the input should be balanced and I wouldn't want to use a transformer for that.
Electrolytics on the output could probably eliminated. Some other electret mic circuits don't need them. The Schoeps and Dorsey circuits also don't use electrolytics on the output. It may be more difficult to get rid of the input caps. I would at least like to be able to use polyester caps. Rising the impedance could be a way to go, I guess. At 16 k input impedance a 1µ cap would do (10 Hz lowpass frequency). Given the bassy response of the mic itself, a bit of low cut would be acceptabe.
The more I think about about this project, the more I realize that it is perhaps more akin to a microphone preamp than an electric mic circuit. Source impedance is around 200 ohms and output impedance should be around 200 ohms as well, perhaps lower. Input and output should be balanced. Special requirements are that it should operate on phantom power and produce optimal performance for 6-12 dB of gain.
That actually made me think of PRR's 48V single ended preamp.
Here's PRR's thread. Maybe that design could be scaled down for as little gain as we need and as little current as we can get from phantom power.
@ Brad: I don't think reviewing necessarily leads to envy and resentment. That may be the case when it comes to books, because a lot of reviewers are frustrated novelists or poets. But that frustration, I think, came before they became reviewers. I became a gear reviewer by chance. If I was frustrated by anything it was the sometimes sloppy work of other gear reviewers. I'm definetly not a frustrated designer. In fact, I have nothing but the greatest respect for good engineering. A good schematic is a bit like a good poem. Everything must fit and work hand in hand. You see a brilliant mind at work, intelligent decisions being made, and sometimes there is an element of staggering creativity. At times there's something that you don't understand, but, hey, it's that mysterious little something that makes it sound so great. Both circuits and poems are artifacts of the human mind. So, if I sometimes make excursions into designing, it's only to understand and thus appreciate things better.
re Auster: get The New York Trilogy or Moon Palace. Those two books are as good as it gets, I think. BTW: his wife is a successful novelist, too. Her name is Siri Hustvedt.
