Making a phantom powered preamp with performance similar to a decent console preamp is bound to exceed the resources of phantom power.Its an interesting line of enquirey , thanks for all the help Abbey .
I do fancy the idea of a powered 58 , in something like front of house sound you might have long cable lenghts typically on multicore with foil and drain wire screen and other sources of noise in the cabling etc .
The typical inline fet boosters give 20-25db of gain , why not make gain trimable over a wider range say 20 to 50 db .
They still leave most of the heavy lifting to the mic input on the console , why not make the inline amp full line level output, can a conventional dual rail op amps be made to run from 48 volts supply ?
North-West needs a larger input cap, probably 5-10uF. Probably rather high THD.
good morningNorth-West needs a larger input cap, probably 5-10uF. Probably rather high THD.
North-East looks OK, except the 4.7k should be deleted. Pobably too much gain for guitar. Delete 22uF cap.
South-West has too low input impedance for guitar, needs 500k-1Meg. 2SK170 may run out of juice.
South-East has way too low input impedance for guitar. Delete 4.7k.
But don't trust me on that. You need to experiment.
Current limitation in P48 is essentially due to the 6.8k feeder resistors. Short-circuit current is thus limited to 14mA. The 10mA figure is not the current limit; it's the current that the phantom circuit should be capable of delivering. Nothing in the standard says that the supply should be limited to 10mA.How about using a dedicated phantom power supply that allows more current than a standard console channel .
This is the max current the wall wart is capable of delivering. It means that it can power up to 10 mics at 10mA, but it could also power about 100 U87's.The rockville RNDI-1 promises upto 100ma at 48 volts .
Nevermind! LTSpice's LSK389 wasn't working for me. Replaced them with plain jfets and it works! Hey abbey road d enfer, can you guide me in the right direction for adjusting gain level in your design?Any tips simulating a circuit like this in LTSpice? I can't figure out if my issue is in the phantom power simulation.
Post your circuit, I'll look at it.Any tips simulating a circuit like this in LTSpice? I can't figure out if my issue is in the phantom power simulation.
Gain is controlled by the ratio of drain resistors vs. source resistors.Nevermind! LTSpice's LSK389 wasn't working for me. Replaced them with plain jfets and it works! Hey abbey road d enfer, can you guide me in the right direction for adjusting gain level in your design?
Got it! You use the generic PNP transistors, that have a lower h21e, so with 470k, there is not enough current for the FET's. If you replace them with the recommended BC327-40, gain is correct.Thanks for the help. I switched the jfets to LSK170A. On your schematic, R7 and R8 are labeled as 470k. Is it possible those were simulated as 47k? At 470k, I'm getting attenuation. When I switched those to 47k, I got about 25dB of gain.
