Active Summing Line In Console
iangomes
Toronto, Canada
So I'm thinking of starting a summing project with something like the 1o73 line in boards on here for the input, but I just thought I'd put myself out there and ask if anyone had any other ideas for ways I could go with this project. The final product is going to be a faderless/eqless/line level 24 channel active summing box with sends, busses and inserts in a huge/multiple 19" rack case(s). I can imagine how I would do the line-in neve option, but what about an api option(312 with line in instead of mic?) or something else? Any input or advice would be awesome to help me get started. I can't believe I'm going to try to start this project :S
Thanks! :)
Dear iangomes - This is an ambitious project. I am building a similar mixer right now. The 1o73 boards are a very good choice for the channel inputs. I do not actually know that board very well. As for the API option, that's fairly easy. The API 312 is the mic pre. The API 325 is the line amp card. You want the 325 but the two circuits are very similar. Do some searching around and find that schematic. It's all over the place.... Actually..... go to Jeff Steiger's on-line store at www.classicapi.com and go to his Reference Documents page. The 325 schematic and other juicy stuff is right there. Jeff also has summing amp cards which are pretty nice (very nice actually). Here are a couple of things to keep in mind. Faderless is fine. EQ-less is fine. But the other functions you mention..... aux sends, busses, inserts.... each function can sometimes require another amplifier. So the actual number of amplifiers required for your design and can grow quickly. But if you're careful you can keep that number down to a reasonable level. One channel amplifier can drive the stereo buss and one or more aux busses. Again, you need to be aware of your loads. Also, don't cheap out on the power supply. Make sure it is plenty large enough for good headroom. We could go on for hours on this. Some guys may chime in with "Oh no..... not another summing mixer.....". Yes, this road has been travelled many times before. But it is still a meritable choice. Ask questions. The guys here will help. Be prepared to spend money. A 24-channel mixer like this is not cheap. DW.
