Add a mix control pot to old Whammy pedal ?
frankiev
Member
I have an old Whamyy pedal . Not sure which generation it is but its small and black rather than the red ones . It has an effect only and dry only output jacks . Id like to add a mix control pot for dry/effect . I know how to wire it but I have no idea what value pot to use . Can anyone advise on this
If it were me, I would make a little external box instead of modding the (possibly collectible) Whammy.
Do you have a reason for wanting it built-in?
Either of these will easily fit in a 1590a:
http://tagboardeffects.blogspot.com/2012/02/split-n-blend.html
http://tagboardeffects.blogspot.com/2012/01/mini-blend-jfet.html
Pot will be linear, by the way. I would start with 100K.
That was my idea also . A little external box with 2 1/4 in jacks .
Thanks for the suggestions
I was thinking a pot with the dry on the left leg ,the mix on the right leg ,and output from the center wiper . That wouldnt work?
