drummerman1515
Member
- Joined
- Aug 6, 2019
- Messages
- 7
Hello all!
I have a 3 channel tube mixer (2 mic in - 1 line in) that sum down to one mono output. I would like to take the 2 mic pres and give them direct outs with separate transformers. The current output transformer shows 16k primary/250ohm secondary.
1. Is this even possible?
2. If so, at what point in the circuit would would the transformer be inserted. I am guessing the outputs of the 2 mic pres are combined before feeding the current output transformer and that may be the spot split and send to the new transformers.
3. What transformers would work as decent outputs?
Sorry, no schematic so I will have to trace the signal.
Thanks in advance.
Thanks in advance.
