> advantages of a tertiary winding is that you can pass dc through it if the transformer is gapped.
Same as any other winding?
Also the need for DC in the NFB loop is designer's choice. If it returns to a grid the DC is dang-near Zero.
We often choose not to buy an extra grid for NFB, returning to a Cathode which has some DC. However 1mA in an 8-Ohm winding on a Power amplifier is typically "no" DC in the core. Actually far less than typical plate-winding DC. Even if "balanced" there's 3mA-30mA unbalance between two tubes, and this runs through 30 times more turns than a speaker-impedance winding.
If you must get Damping Factor much below 10, you need to tap NFB from the load winding.
If you need to connect load to any long strange mess of wire, you probably want an added winding just for NFB, so the load can float where it will.
Those of us who live all in one room/suite will probably avoid a Tertiary because it is added cost and complication.
