lassoharp said:
This mixer used a tank with input Z of 100 ohm and output Z of about 300-500 ohms. Peavey doesn't stock them anymore and all the current production tanks use 2250 output Z. (Accutronics will make one with 500 ohm output Z but nobody has them). My question is will it even matter? Or do I need to be concerned with getting a lower output Z tank?
I used to be the manager over the engineering group that designed those. The bad news is I have no specific recollection about the pan used in the XR500, in fact over the years there may have been more than one. The only good news is I know a little about the engineering involved.
Back in the day Peavey literally used truckloads of reverb pans and we had a bunch of different ones in the system. Guitar pans were voiced different than mixer pans and there were even different versions for different mounting orientations. While not obvious but in use the spring will sag down due to gravity, the driver and pick up mechanicals are engineered with a specific orientation in mind. If you use a vertical pan mounted horizontally or vice versa the spring may mechanically bottom out too easily from external vibration and handling.
If you know what year your XR-500 was made you can probably get a copy of the schematic.
I don't expect the drive circuitry to be a true current source, but probably a healthy output voltage source through a series resistor (these are not high end products).
When you say current production tank, which/who's current production? Peavey may still put tanks in cheap guitar amps (maybe?) but I'd bet money they don't put tanks in mixers anymore. Cheap digital efx are probably cheaper than even the cheapest spring reverb.
A guitar tank will be voiced differently than a powered mixer tank... Don't ask me to give all the details because I don't remember them, just that they were different.
Do you have the old tank? What's wrong with it? It may just be a broken wire or solder connection in the send or pickup transducer. I am pretty sure the springs don't wear out. You best bet for stock sounding repair, is to fix the old tank if possible... Not rocket science, but science.
If you decide to go with a replacement tank and it has higher output Z that just means more windings on the output transducer so more output voltage. Again looking at the schematic might suggest the best way to scrub off some extra gain, I wouldn't pad it down, to then boost it back up again, reverbs never were very quiet to start with. Too much tank output could distort the fixed gain preamp.
Note: I higher Z pickup might (?) also pick up more transformer hum. It was always a balancing act to mount the spring inside a powered head without too much hum. I would expect this to be linear, so scrubbing off gain in the preamp should get S/N back in line. In fact the hotter pickups should deliver better S/N
PS: When we started making guitar amps over in China we literally had to ship US made reverb tanks to China, since they were never able to source a Chinese made spring reverb that didn't suck...
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
