Matt C
So I'm in the process of modifying an Akai M8 machine to be used as mic preamps, and I'm hoping the people here would be willing to offer some help so I can better understand this circuit. I'm new to electronics in general and new to tube circuits, so bear with me.
I took everything out of the unit and rebuilt it from the ground up as a single channel mic preamp. the circuit is mostly based on the "Tablebeast Brute Force" design which can be seen below (let me reiterate that this schematic is not my own design. thanks to Jesse/xfmr for sharing it). I've got everything more or less working, but I'm trying to learn as much as possible from this project (and end up with nice preamps), so I'm taking some time to read about tube circuits and try to figure out if there are any changes I can/should make for my own units. Keep in mind I'm still just learning this stuff, so while I'm happy to make changes to the circuit, changing the design completely would be biting off more than I can chew. here's a rundown of the issues/questions that have come up. any help and advice would be greatly appreciated!:
- B+ voltage is 207 Vdc
- right now in the EF86 stage, quiescent plate voltage is only 52V, while the screen grid is at 79V. my understanding is that we usually want the screen to be lower than the plate. I didn't make any changes to that part of the circuit, so if this an indication that something is wrong? or am I just incorrect in what voltages I'm expecting to see there?
- one main difference in my unit compared to the posted schematic is the input - I left out the 243R and 500k resistors on the input transformer secondary, and replaced them with a 500k pot across the secondary with the wiper connected to the EF86 control grid. this seems to work but I'm worried it's an inelegant way to add an input volume control. more specifically I'm wondering if it is creating problems because the part of the pot below the wiper is acting as a grid leak resistor, but when the pot is turned down low, you end up with a grid leak resistor that's much smaller than what usually gets used. is this actually an issue or am I just making things up at this point?
- when adding a polarity switch, is it preferable to put it at the input, or the output? one person recommended switching at the output, because he thought it was generally bad practice to switch low level signals if you don't have to. my other thought, which I'm not sure is really valid, is that since a tube can distort a wave asymmetrically, flipping the polarity at the input could have a noticeable effect on the tone when pushing the tube hard. any truth to that?
- am I correct in thinking that the input impedance of the preamp is essentially set by whatever resistance is across the secondary, reflected back through to the primary by the square of the turns ratio? so if I want the input impedance to be around 1.5k, and I use a 1:7 input transformer, I'd want around 73.5k (1.5k * 49) across the secondary? Basically I'm confused about how to make all the resistances on the input (transformer zobel network, grid leak and grid stopper resistors, input volume control) play nice together and still end up with the right input impedance. the input transformer I intend to use is the Cinemag CMMI-7C which is 50,200:9.8k, and the datasheet recommends a damping network on the secondary.
- a more vague question, and maybe you can just point me toward some recommended reading, but when trying to reduce noise in this circuit, what are some ways of sorting out which noises are coming from where? I tried the unit out briefly today and didn't have any major noise problems, but with the volume cranked up there was definitely some hum that I'd like to at least try to reduce.
- right now all my AC heater voltages are about 0.7V too high. is it worth adding a dropping resistor in series with the heaters to bring them back down to the recommended levels, or is that extra voltage not significant?
