Hansblooey Ribbon
Active member
- Joined
- Apr 26, 2023
- Messages
- 35
Coming apart easily enough. The PCBs are solder wicking very well.
Yeah I get it,I think it was a thing at one time...
I'd put some conductive tape on there to cover the holes. Or maybe some aluminum either welded or attached with contact cement. Maybe the capsule is well grounded enough it isn't necessary but I'd worry about contamination too.Friends don't Let Friends...
Have one working well now. All the tantalums were near zero ohms.
The other parts were the Vishay box resistors. Some bizarre resistor values I had to use the nearest.
Not too bothered by the holes in the body.
Replaced parts:
R01 14.3K
R02 6.65K
R06 820R
R111 2.7K
R118 47R
C09 220uF/ 25V
C10 22nF
C05, 06, 08, 11, 106, 10uF/25V
C110 4n7
C113 3.3uF/ 50V
C114 1uF/ 35V
I also think it's better to close the holes to make sure the mic works properly under all circumstances.Not too bothered by the holes in the body.
WOW WOW WOW!Friends don't Let Friends...
Replaced parts:
R01 14.3K
R02 6.65K
R06 820R
R111 2.7K
R118 47R
C09 220uF/ 25V
C10 22nF
C110 4n7
C113 3.3uF/ 50V
C114 1uF/ 35V
