micolas
@Frdfrode
What Khron said is correct. 151 and 620 are SMD inductors, 150uH and 62uH, D3 is the zenner diode, to find out its stabilization voltage measure the voltage across it.
To find the correct output voltage of the DC/DC converter, you need to measure after the voltage doubler, between GND and the D6+R12 connection (and it is slightly lower at the end of the 1Gohm coming from the converter). Possibly the voltage generated by the DC/DC is more than 24.5v. (It depends on the internal resistance of your multimeter too)
Maybe the phantom voltage is substantially lower than 48v. You have to measure it without the microphone connected and then with the microphone connected, on XLR, 2 vs. 1 and 3 vs. 1(GND).
