Hello,
I'm having some issues with my AKG C414 B uls. Recently, I heard some intermittent electrical noise while tracking that sounds like static or light electrical distortion that sometimes has a clicking sound for a moment and then it goes away. It's very intermittent and I thought it was ground loops or something for a while and then realized it was probably something else after moving connections around. I since did a process of elimination in all my gear and it is the 414. It does not matter what pattern is selected or if the pad or roll off is selected or not but it comes and goes. It seems to be even more frequent now. I also noticed an unnatural distortion sound on some vocals I was tracking the other day that occurred on quiet parts (so not from overloading the transformer) that seemed to coincide with the noise problem. I have attached a clip of the noise on a gearslutz post that you can reference here: https://www.gearslutz.com/board/so-much-gear-so-little-time/1011243-akg-c414-b-uls-mysterious-electrical-noise-problem.html
Does anyone have an idea as to what this might be?
Thanks for the help,
Matt
Matt
