AKG C451LB vs C451B vs 451E
smilan
I picked an AKG C451LB with CK1 capsule from ebay as non working, it came with no small tuchel jack so I installed one and now it works and sounds pretty good.
I have a modern C 451-B (with non removal CK1 capsule).
There's a big difference between the tow microphones.
The modern C451B have much more hi frequencies comparing to the C451LB.
I took a C451E preamp and with the same CK1 capsule both E and LB preamps sounds pretty similar, the E have a little bit more high frequencies than the LB.
On the other hand, the C451-B have much more hi frequencies comparing to the C451LB end E (with a different capsule).
Since I don't have another CK1 capsule I'm wondering if the C451LB works fine or the capsule is faulty.
In this lint you'll find sound samples of the three mics (with the two CK1 capsules).
