SonsOfThunder
Okay...
There seems to be some interest in this so I'll start here. Who can host the images for me? I should have some pics and some pdf graphs soon. I know I have graphs at work on the unit in its stock state but I don't think I have graphed the sweeps since I modded (two iterations).
These things are actually a decent basis for an acceptable amp, after mods. If nothing else, you can use the chassis, heatsinks and power trafo, and etch and stuff your own design here. You'll spend more than the cost of a used one of these for those parts alone.
The design is all discrete (no ICs at all). Unbalanced input. It uses a pair of BJT outputs per channel each in a big plastic case. It makes about 150W per channel into 4 ohms and about 100W per at 8 Ohms...I'm a little fuzzy on the 8 Ohm ouput at the moment. I think its rated at 75W per ch at 8 Ohms? Seems like typical class A/B design, though I've not seen nor made a schematic...yet!
The first thing to go were those crappy push terminals for the speaker outs. Buh-bye! Used a jigsaw to open up the rectangular hole and installed banana jacks mounted on a piece of unplated fiberglass PCB. Input jacks (1/4 inch) and the 1/4 inch output jacks are also mounted on the sub PCB with the push terms. I removed the whole I/O PCB and then desoldered the plastic 1/4 inch input jacks to reuse. I liked the idea of not grounding the inputs to the chassis directly and this has worked fine.
More later! Peace!
Charlie
More later! Peace!
Charlie
